Ana içeriğe geç
Leica Z2X Flash Diffuser Replacement
Neye ihtiyacın var
  1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: adım 1, 1 resimden 1.
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: adım 2, 1 resimden 1.
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: adım 3, 1 resimden 1.
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: adım 4, 1 resimden 1.
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  5. Leica Z2X Flash Diffuser Replacement: adım 5, 1 resimden 1.
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  6. Leica Z2X Flash Diffuser Replacement: adım 6, 1 resimden 1.
    • You should now have removed the front and back plates.
  7. Leica Z2X Flash Diffuser Replacement: adım 7, 1 resimden 1.
    • Removing the flash diffuser should be simple from here.
    • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kenny
57 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G19
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 3,518
