Neye ihtiyacın var
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Open the back door on the camera by pushing down on the door latch.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
From here, locate the three screws near the front of the lens.
Unscrew these three screws.
Bir başkası bu kılavuzu tamamladı.
