Ana içeriğe geç
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
Neye ihtiyacın var
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 2, 2 resimden 1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 3, 2 resimden 1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: adım 4, 1 resimden 1.
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
Sonuç
Bir Yorum
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 880
