Giriş
This guide will show you how to access and replace the hinges in your Lenovo 100e Chromebook 2nd Gen laptop, in the circumstance that your device is no longer opening/closing correctly.
Neye ihtiyacın var
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
Bir Yorum
Any Ideas on how to repair popped rivets from the hinges? I've tried epoxy without much luck, but I've got hinges popped at the top and bottom of the display.
