Ana içeriğe geç
Lenovo 100s Chromebook-11IBY Screen Replacement
Neye ihtiyacın var
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 3, 2 resimden 1. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 3, 2 resimden 2.
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 4, 1 resimden 1.
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 5, 2 resimden 1. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 5, 2 resimden 2.
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 6, 1 resimden 1.
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 7, 1 resimden 1.
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 8, 1 resimden 1.
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 9, 2 resimden 1. Lenovo 100s Chromebook-11IBY Screen Replacement: adım 9, 2 resimden 2.
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Milton Perez
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G2
1 Üye
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,712
