Ana içeriğe geç
Lenovo 100s Chromebook-11IBY Speaker Replacement
Neye ihtiyacın var
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: adım 1, 1 resimden 1.
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 2, 1 resimden 1.
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 3, 2 resimden 1. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 3, 2 resimden 2.
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 4, 3 resimden 1. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 4, 3 resimden 2. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 4, 3 resimden 3.
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 5, 1 resimden 1.
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 6, 2 resimden 1. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 6, 2 resimden 2.
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: adım 7, 1 resimden 1.
    • Repeat steps 5 & 6 in order to remove the right speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Milton Perez
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G2
1 Üye
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 519
