Ana içeriğe geç
Lenovo 100s Chromebook-11IBY Webcam Replacement
Neye ihtiyacın var
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: adım 1, 1 resimden 1.
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 3, 2 resimden 1. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 3, 2 resimden 2.
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 4, 2 resimden 1. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 5, 1 resimden 1.
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 6, 2 resimden 1. Lenovo 100s Chromebook-11IBY Webcam Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Sonuç
Milton Perez
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G2
1 Üye
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 330
