Giriş
This guide shows you how to replace the battery in the Lenovo 300e Chromebook 2nd Gen Laptop. This guide is moderate difficulty as you will only be unscrewing, remove the backing and disconnecting the battery cable
It's highly recommended that you use an Anti-Static Wrist Strap for this guide as you will be working on exposed electronics.
Neye ihtiyacın var
Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
Use an opening tool such as a spudger and carefully work your way around the laptop to remove the back cover
Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
It should be mentioned that "newer" models of this particular Chromebook are/have been released. The Chromebooks' battery compartment's design have been slightly modified in that the battery compartment are now reversed.
So, since the battery's connector cable is so short, it's impossible to twist it to fit.
So, make sure you're getting the correct battery for the correct "model".
FYI, the "older" models have the power button close to the back corner of the device, and the "newer" models have the power button near the middle of the device.
