Ana içeriğe geç
Lenovo 300e Chromebook Battery Replacement
Neye ihtiyacın var
  1. Lenovo 300e Chromebook Battery Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo 300e Chromebook Battery Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo 300e Chromebook Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Battery Replacement: adım 2, 3 resimden 1. Lenovo 300e Chromebook Battery Replacement: adım 2, 3 resimden 2. Lenovo 300e Chromebook Battery Replacement: adım 2, 3 resimden 3.
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Battery Replacement, Battery: adım 3, 3 resimden 1. Lenovo 300e Chromebook Battery Replacement, Battery: adım 3, 3 resimden 2. Lenovo 300e Chromebook Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Battery Replacement: adım 4, 3 resimden 1. Lenovo 300e Chromebook Battery Replacement: adım 4, 3 resimden 2. Lenovo 300e Chromebook Battery Replacement: adım 4, 3 resimden 3.
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
Sonuç
To reassemble your device, follow these instructions in reverse order with the new battery.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 932
