Ana içeriğe geç
Lenovo 300e Chromebook Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Motherboard  Replacement: adım 2, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement: adım 2, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement: adım 2, 3 resimden 3.
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Motherboard  Replacement, Battery: adım 3, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement, Battery: adım 3, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement, Battery: adım 3, 3 resimden 3.
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Motherboard  Replacement: adım 4, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement: adım 4, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement: adım 4, 3 resimden 3.
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: adım 5, 2 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the three silver 3 mm screws from the center of the metal cover using a Phillips #00 screwdriver.
  6. Lenovo 300e Chromebook Motherboard  Replacement: adım 6, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement: adım 6, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement: adım 6, 3 resimden 3.
    • Remove two 3 mm screws from the top of the metal cover using a Phillips #2 screwdriver.
    • Remove the metal cover from the laptop.
  7. Lenovo 300e Chromebook Motherboard  Replacement: adım 7, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement: adım 7, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement: adım 7, 3 resimden 3.
    • Remove the nine 3 mm screws from the motherboard using a Phillips #2 screwdriver.
    • Detach all the connectors from the motherboard.
  8. Lenovo 300e Chromebook Motherboard  Replacement: adım 8, 3 resimden 1. Lenovo 300e Chromebook Motherboard  Replacement: adım 8, 3 resimden 2. Lenovo 300e Chromebook Motherboard  Replacement: adım 8, 3 resimden 3.
    • Remove the tape using a spudger.
    • Disconnect the large cable connector.
    • Remove the motherboard from the laptop.
Sonuç
Bir Yorum
where is the write protect screw located im trying to install windows on this model
Harvey Willis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 1,235
