Giriş
This guide will show how to remove the speakers in the Lenovo 300e Chromebook. The speakers have screws that require the use of a #2 Phillips screwdriver to remove. While not a long or difficult process, the speakers are fragile so make sure to take caution when putting the new ones in.
Neye ihtiyacın var
Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
Remove a single 5 mm screw from each speaker using a Phillips #2 screwdriver.
