Ana içeriğe geç
Lenovo 300e Chromebook USB and Charging Ports Replacement
Neye ihtiyacın var
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 2, 3 resimden 1. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 2, 3 resimden 2. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 2, 3 resimden 3.
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: adım 3, 3 resimden 1. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: adım 3, 3 resimden 2. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: adım 3, 3 resimden 3.
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 4, 3 resimden 1. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 4, 3 resimden 2. Lenovo 300e Chromebook USB and Charging Ports Replacement: adım 4, 3 resimden 3.
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 44
Her zaman: 1,454
