Ana içeriğe geç
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 2, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 3, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 3, 2 resimden 2.
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 5, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 8, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 9, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 9, 2 resimden 2.
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 10, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 10, 2 resimden 2.
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 12, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 13, 3 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 13, 3 resimden 2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 13, 3 resimden 3.
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 14, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 14, 2 resimden 2.
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 15, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 15, 2 resimden 2.
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 16, 3 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 16, 3 resimden 2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 16, 3 resimden 3.
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 17, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 17, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: adım 18, 1 resimden 1.
    • Gently remove the motherboard from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 51
Her zaman: 751
