Ana içeriğe geç
Lenovo 500e Chromebook 2nd Gen Speakers Replacement
Neye ihtiyacın var
  1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 2, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 2, 2 resimden 2.
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 3, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 3, 2 resimden 2.
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 5, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 5, 2 resimden 2.
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: adım 7, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: adım 7, 2 resimden 2.
    • Remove the two 4 mm screws (one on each speaker) using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 8, 2 resimden 1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 8, 2 resimden 2.
    • Use the iFixit opening tool to detach the right speaker cable from the motherboard.
  9. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: adım 9, 1 resimden 1.
    • Remove both speakers by gently pulling them out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 168
