Ana içeriğe geç
Lenovo A8-50 Motherboard and Speaker Replacement
Neye ihtiyacın var
  1. Lenovo A8-50 Motherboard and Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Motherboard and Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Motherboard and Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Motherboard and Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Motherboard and Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
  6. Lenovo A8-50 Motherboard and Speaker Replacement, Motherboard and Speaker: adım 6, 1 resimden 1.
    • Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
    • Set aside carefully.
  7. Lenovo A8-50 Motherboard and Speaker Replacement: adım 7, 2 resimden 1. Lenovo A8-50 Motherboard and Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the two black panels and the clear circle piece.
  8. Lenovo A8-50 Motherboard and Speaker Replacement: adım 8, 1 resimden 1.
    • Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
  9. Lenovo A8-50 Motherboard and Speaker Replacement: adım 9, 1 resimden 1.
    • Lift the bottom speaker piece up carefully
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jay Shah
503 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 1,280
