Ana içeriğe geç
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: adım 2, 2 resimden 1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: adım 2, 2 resimden 2.
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: adım 3, 2 resimden 1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: adım 3, 2 resimden 2.
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): adım 4, 3 resimden 1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): adım 4, 3 resimden 2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): adım 4, 3 resimden 3.
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: adım 5, 2 resimden 1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: adım 5, 2 resimden 2.
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 3.
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: adım 7, 1 resimden 1.
    • That's all.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
191.470 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.485 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 76
Her zaman: 7,312
