Ana içeriğe geç
Lenovo B575-1450 RAM Replacement
Neye ihtiyacın var
  1. Lenovo B575-1450 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 RAM Replacement: adım 2, 2 resimden 1. Lenovo B575-1450 RAM Replacement: adım 2, 2 resimden 2.
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 RAM Replacement: adım 3, 3 resimden 1. Lenovo B575-1450 RAM Replacement: adım 3, 3 resimden 2. Lenovo B575-1450 RAM Replacement: adım 3, 3 resimden 3.
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 RAM Replacement, Back Panel: adım 4, 2 resimden 1. Lenovo B575-1450 RAM Replacement, Back Panel: adım 4, 2 resimden 2.
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 RAM Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 RAM Replacement: adım 6, 1 resimden 1.
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 RAM Replacement, RAM: adım 7, 2 resimden 1. Lenovo B575-1450 RAM Replacement, RAM: adım 7, 2 resimden 2.
    • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
    • Pull the RAM out from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,257
