Giriş
This guide will instruct you on how to replace your Edge 15’s hard drive disk (HDD), or upgrade to a compatible solid state drive (SSD). Physical replacement of the hardware is a simple job, but installing an operating system (OS) on the new drive can be more involved.
This video may be helpful in showing you how to download a Windows operating system file and install it on your new hard drive: https://www.youtube.com/watch?v=tjmRWFep...
Neye ihtiyacın var
Locate the eleven M2 x 6.0mm back-cover screws.
Unscrew the screws using the Phillips #0 screwdriver.
Set the battery aside. This will allow easier access to the connector for the HDD.
During assembly, take careful note of the following items:
1) Keep track of the correct screws for each application.
2) Components may need to be wiggled to allow for proper screw alignment.
3) Don’t force screws in to avoid cross-threading.
4) Ensure proper connector alignment when reconnecting the HDD and battery cables.
Again, here is a video to help install a Windows OS on your new HDD: https://www.youtube.com/watch?v=tjmRWFep...
3 farklı kişi bu kılavuzu tamamladı.
