Giriş
This is a step by step guide on how to remove the fan assembly on the Lenovo Thinkpad Edge E431.
Neye ihtiyacın var
Close the device and remove all power cables.
Lay the laptop flat with the bottom facing upwards.
Remove the nine 2mm Phillips screws from the cooling assembly.
Using the tweezers, remove the fan power cable from the motherboard.
Bir başkası bu kılavuzu tamamladı.
