Ana içeriğe geç
Lenovo Essential B570 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Essential B570 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 Hard Drive Replacement, Back Panel: adım 3, 1 resimden 1.
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 Hard Drive Replacement: adım 4, 3 resimden 1. Lenovo Essential B570 Hard Drive Replacement: adım 4, 3 resimden 2. Lenovo Essential B570 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 1. Lenovo Essential B570 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 2. Lenovo Essential B570 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Pull the Hard Drive out of its socket.
    • Lift the tab upwards to remove the hard drive.
    • If you cannot pull the hard drive out of its socket, there is a possibility that there is a 4mm Phillips #1 screw securing it. Locate it and remove it before continuing. It is in very close proximity to the black tab.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Samuel Filliettaz
855 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 4,742
