Ana içeriğe geç
Lenovo Essential B570 RAM Replacement
Neye ihtiyacın var
  1. Lenovo Essential B570 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Lenovo Essential B570 RAM Replacement: adım 2, 1 resimden 1.
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
    FixBot'a Sor
    Yorum Ekle
  3. Lenovo Essential B570 RAM Replacement, Back Panel: adım 3, 1 resimden 1.
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Lenovo Essential B570 RAM Replacement: adım 4, 3 resimden 1. Lenovo Essential B570 RAM Replacement: adım 4, 3 resimden 2. Lenovo Essential B570 RAM Replacement: adım 4, 3 resimden 3.
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
    FixBot'a Sor
    Yorum Ekle
  5. Lenovo Essential B570 RAM Replacement, RAM: adım 5, 2 resimden 1. Lenovo Essential B570 RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Release your RAM by pulling its locks away from one another.
    FixBot'a Sor
    Yorum Ekle
  6. Lenovo Essential B570 RAM Replacement: adım 6, 2 resimden 1. Lenovo Essential B570 RAM Replacement: adım 6, 2 resimden 2.
    • Remove RAM by carefully pulling it away from its socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samuel Filliettaz
900 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,299
