Ana içeriğe geç
Lenovo Essential G555-0873 CPU Replacement
Neye ihtiyacın var
  1. Lenovo Essential G555-0873 CPU Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 CPU Replacement: adım 2, 1 resimden 1.
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 CPU Replacement, Fan: adım 3, 1 resimden 1.
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 CPU Replacement: adım 4, 1 resimden 1.
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 CPU Replacement: adım 5, 1 resimden 1.
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 CPU Replacement, Heat Sink: adım 6, 1 resimden 1.
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 CPU Replacement: adım 7, 2 resimden 1. Lenovo Essential G555-0873 CPU Replacement: adım 7, 2 resimden 2.
    • Pull the heat sink assembly out of the laptop.
  8. Lenovo Essential G555-0873 CPU Replacement, CPU: adım 8, 2 resimden 1. Lenovo Essential G555-0873 CPU Replacement, CPU: adım 8, 2 resimden 2.
    • Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
  9. Lenovo Essential G555-0873 CPU Replacement: adım 9, 1 resimden 1.
    • Remove the CPU
    • There will be old thermal paste on the CPU and heat sink which should be wiped off using microfiber cloth.
    • Before putting the heat sink back in, a small droplet of thermal paste should be applied onto the center of the CPU.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 382
