Ana içeriğe geç
Lenovo Essential G560 Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo Essential G560 Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Back Panel Replacement: adım 2, 2 resimden 1. Lenovo Essential G560 Back Panel Replacement: adım 2, 2 resimden 2.
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Back Panel Replacement: adım 3, 1 resimden 1.
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Back Panel Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 Back Panel Replacement: adım 5, 2 resimden 1. Lenovo Essential G560 Back Panel Replacement: adım 5, 2 resimden 2.
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 Back Panel Replacement: adım 6, 1 resimden 1.
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Lawrence Downs
383 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G40
5 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 4,938
