Ana içeriğe geç
Lenovo Essential G560 Keyboard Replacement
Görüntüleme: 20 B
İstatistikleri görüntüle:
Son 24 Saat:
Son 7 Gün:
25
Son 30 Gün:
101
Her zaman:
19.762
Yorumlar: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Tamamlandı: 13
13 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 2
2 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 10 - 15 dakika
Zorluk: Orta
This guide will detail the steps necessary to remove the keyboard from the Lenovo Essential G560 laptop. Please note that this is not an easy process and may take a bit of patience, especially when reinstalling or installing the new keyboard.
Neye ihtiyacın var
Aletler
    1. Lenovo Essential G560 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the cable could result in electric shock.
      • Flip the computer upside down.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G560 Keyboard Replacement: adım 2, 2 resimden 1. Lenovo Essential G560 Keyboard Replacement: adım 2, 2 resimden 2.
      • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G560 Keyboard Replacement: adım 3, 1 resimden 1.
      • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G560 Keyboard Replacement, Back Panel: adım 4, 1 resimden 1.
      • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G560 Keyboard Replacement: adım 5, 2 resimden 1. Lenovo Essential G560 Keyboard Replacement: adım 5, 2 resimden 2.
      • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G560 Keyboard Replacement: adım 6, 1 resimden 1.
      • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G560 Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
      • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
      • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G560 Keyboard Replacement: adım 8, 1 resimden 1.
      • Flip the computer over.
      • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G560 Keyboard Replacement: adım 9, 1 resimden 1.
      • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
      • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo Essential G560 Keyboard Replacement: adım 10, 1 resimden 1.
      • Lift the keyboard up from the bezel.
      • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
      • Carefully pull the keyboard cable from its socket.
      • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Dennis Wong
618 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G40
5 Üyeler
84 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you frndzz
Anand krishnan - Yanıt Paylaş
Thank you frndz
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 101
Her zaman: 19,762
