Ana içeriğe geç
Lenovo Essential G560 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Essential G560 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Keyboard Replacement: adım 2, 2 resimden 1. Lenovo Essential G560 Keyboard Replacement: adım 2, 2 resimden 2.
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Keyboard Replacement: adım 3, 1 resimden 1.
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Keyboard Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    a few of my screws are not coming out
    Jonathan Lewin - Yanıt
    Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
    Denskwik K - Yanıt
    I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
    Alex Kuriakose - Yanıt
  5. Lenovo Essential G560 Keyboard Replacement: adım 5, 2 resimden 1. Lenovo Essential G560 Keyboard Replacement: adım 5, 2 resimden 2.
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    I was having the same problem as the 11 year old from the previous step, and contrary to this note I just stuck my screwdriver under that tab and pried it off. It worked. It wasn’t even hard.
    lmh237 - Yanıt
  6. Lenovo Essential G560 Keyboard Replacement: adım 6, 1 resimden 1.
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
    • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
  8. Lenovo Essential G560 Keyboard Replacement: adım 8, 1 resimden 1.
    • Flip the computer over.
    • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
  9. Lenovo Essential G560 Keyboard Replacement: adım 9, 1 resimden 1.
    • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
    • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
  10. Lenovo Essential G560 Keyboard Replacement: adım 10, 1 resimden 1.
    • Lift the keyboard up from the bezel.
    • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull the keyboard cable from its socket.
    • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
    This step need more detailed explanation
    (with additional pictures) because it
    crucial.
    Anthony
    Anthony Pek - Yanıt
    Excellent. Fixed thank you
    Mox Henderson - Yanıt
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Dennis Wong
609 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G40
5 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you frndzz
Anand krishnan - Yanıt
Thank you frndz
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 18,779
