Giriş
This guide will detail the steps necessary to remove the keyboard from the Lenovo Essential G560 laptop. Please note that this is not an easy process and may take a bit of patience, especially when reinstalling or installing the new keyboard.
Neye ihtiyacın var
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
a few of my screws are not coming out
Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
Lift the keyboard up from the bezel.
Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
Carefully pull the keyboard cable from its socket.
This step need more detailed explanation
(with additional pictures) because it
crucial.
Anthony
Excellent. Fixed thank you
13 farklı kişi bu kılavuzu tamamladı.
