Ana içeriğe geç
Lenovo Essential G570 Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo Essential G570 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the laptop over so that the bottom side is facing up.
  2. Lenovo Essential G570 Back Panel Replacement: adım 2, 1 resimden 1.
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  3. Lenovo Essential G570 Back Panel Replacement: adım 3, 3 resimden 1. Lenovo Essential G570 Back Panel Replacement: adım 3, 3 resimden 2. Lenovo Essential G570 Back Panel Replacement: adım 3, 3 resimden 3.
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin Bickford
446 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S1G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,533
