Ana içeriğe geç
Lenovo Essential G570 Fan Replacement
Neye ihtiyacın var
    1. Lenovo Essential G570 Fan Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to unplug the cable could result in electric shock.
      • Turn the computer upside down.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 Fan Replacement: adım 2, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 2, 2 resimden 2.
      • Locate the two switches that lock the battery.
      • Push the right switch outwards to unlock the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G570 Fan Replacement: adım 3, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 3, 2 resimden 2.
      • Push and hold the left switch outwards to unlock the battery.
      • Pull the battery away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G570 Fan Replacement, Back Panel: adım 4, 1 resimden 1.
      • Turn the laptop over so that the bottom side is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 Fan Replacement: adım 5, 1 resimden 1.
      • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
      • The screws do not come out fully from the back plate. They stay attached to the plate itself.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 1. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 2. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 3.
      • With the screws removed, insert the plastic opening tool into the groove located on the right side.
      • Begin to pry up, and the plate should lift up from the body of the laptop.
      • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G570 Fan Replacement, Fan: adım 7, 2 resimden 1. Lenovo Essential G570 Fan Replacement, Fan: adım 7, 2 resimden 2.
      • Carefully pull the fan's power connector from the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 Fan Replacement: adım 8, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 8, 2 resimden 2.
      • Remove the three 5mm Phillips #1 screws holding the fan in place.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G570 Fan Replacement: adım 9, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 9, 2 resimden 2.
      • Remove the fan by pulling it up and away from the computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucio
235 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S1G1
3 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 986
