Ana içeriğe geç
Lenovo Essential G570 Fan Replacement
Neye ihtiyacın var
  1. Lenovo Essential G570 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Fan Replacement: adım 2, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 2, 2 resimden 2.
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Fan Replacement: adım 3, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 3, 2 resimden 2.
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Fan Replacement, Back Panel: adım 4, 1 resimden 1.
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Fan Replacement: adım 5, 1 resimden 1.
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 1. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 2. Lenovo Essential G570 Fan Replacement: adım 6, 3 resimden 3.
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Fan Replacement, Fan: adım 7, 2 resimden 1. Lenovo Essential G570 Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Carefully pull the fan's power connector from the laptop.
  8. Lenovo Essential G570 Fan Replacement: adım 8, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 8, 2 resimden 2.
    • Remove the three 5mm Phillips #1 screws holding the fan in place.
  9. Lenovo Essential G570 Fan Replacement: adım 9, 2 resimden 1. Lenovo Essential G570 Fan Replacement: adım 9, 2 resimden 2.
    • Remove the fan by pulling it up and away from the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucio
217 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S1G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 613
