Ana içeriğe geç
Lenovo Essential G570 RAM Replacement
Neye ihtiyacın var
    1. Lenovo Essential G570 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to unplug the cable could result in electric shock.
      • Turn the computer upside down.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 RAM Replacement: adım 2, 2 resimden 1. Lenovo Essential G570 RAM Replacement: adım 2, 2 resimden 2.
      • Locate the two switches that lock the battery.
      • Push the right switch outwards to unlock the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G570 RAM Replacement: adım 3, 2 resimden 1. Lenovo Essential G570 RAM Replacement: adım 3, 2 resimden 2.
      • Push and hold the left switch outwards to unlock the battery.
      • Pull the battery away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G570 RAM Replacement, Back Panel: adım 4, 1 resimden 1.
      • Turn the laptop over so that the bottom side is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 RAM Replacement: adım 5, 1 resimden 1.
      • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
      • The screws do not come out fully from the back plate. They stay attached to the plate itself.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo Essential G570 RAM Replacement: adım 6, 3 resimden 1. Lenovo Essential G570 RAM Replacement: adım 6, 3 resimden 2. Lenovo Essential G570 RAM Replacement: adım 6, 3 resimden 3.
      • With the screws removed, insert the plastic opening tool into the groove located on the right side.
      • Begin to pry up, and the plate should lift up from the body of the laptop.
      • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo Essential G570 RAM Replacement, RAM: adım 7, 1 resimden 1.
      • Using your fingers, hold open the two clips holding the top RAM in place.
      • The two RAM chips are placed one on top of another. It is important to take the top one out first to easily access the bottom one.
      • With the clips held away from the RAM, slide the top stick out from it's connection.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo Essential G570 RAM Replacement: adım 8, 1 resimden 1.
      • With the top RAM stick removed, repeat the same process for the bottom piece. Begin by holding the two clips away from the RAM.
      • With the clips held out, slide the RAM out from the connection.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin Bickford
479 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 UMass Dartmouth, Team S1-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S1G1
3 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,118
