Giriş
The RAM of the computer is responsible for running all of the programs while the computer is powered on. If a user experiences the computer freezing during operation, it may be due to the RAM being too small or too slow. To fix this, upgrading the RAM is often a quick and easy solution to speeding up the performance of your laptop. This guide goes through the necessary steps in order to replace the RAM currently in the computer.
Neye ihtiyacın var
Turn off the laptop.
Disconnect the charging cable.
Turn the computer upside down.
Using your fingers, hold open the two clips holding the top RAM in place.
With the clips held away from the RAM, slide the top stick out from it's connection.
3 farklı kişi bu kılavuzu tamamladı.
