Ana içeriğe geç
Lenovo Flex 3-1120 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo Flex 3-1120 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: adım 6, 2 resimden 1. Lenovo Flex 3-1120 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: adım 9, 1 resimden 1.
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: adım 10, 1 resimden 1.
    • Lift the hard drive out from the computer.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Geoff Bentz
934 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G1
4 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
How do you reload operating system.... for example windows 10?
supermac200 - Yanıt
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Yanıt
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Yanıt
That sata connector is the worst thing ever
dilleremail - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 10,889
