Ana içeriğe geç
Lenovo Flex 3-1120 Network Card Replacement
Neye ihtiyacın var
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: adım 2, 2 resimden 1. Lenovo Flex 3-1120 Network Card Replacement: adım 2, 2 resimden 2.
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: adım 4, 1 resimden 1.
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: adım 5, 1 resimden 1.
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: adım 6, 2 resimden 1. Lenovo Flex 3-1120 Network Card Replacement: adım 6, 2 resimden 2.
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: adım 7, 1 resimden 1.
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: adım 8, 2 resimden 1. Lenovo Flex 3-1120 Network Card Replacement: adım 8, 2 resimden 2.
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
Sonuç
Geoff Bentz
934 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G1
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 798
