Ana içeriğe geç
Lenovo Flex 3-1120 Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: adım 2, 2 resimden 1. Lenovo Flex 3-1120 Speakers Replacement: adım 2, 2 resimden 2.
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: adım 4, 1 resimden 1.
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: adım 6, 2 resimden 1. Lenovo Flex 3-1120 Speakers Replacement: adım 6, 2 resimden 2.
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: adım 7, 2 resimden 1. Lenovo Flex 3-1120 Speakers Replacement: adım 7, 2 resimden 2.
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: adım 8, 1 resimden 1.
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Sonuç
Geoff Bentz
934 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 422
