Ana içeriğe geç
Lenovo Flex 6-11IGM Heat Sink Replacement
Neye ihtiyacın var
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 2, 2 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 2, 2 resimden 2.
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 4, 2 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 4, 2 resimden 2.
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: adım 5, 2 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 6, 3 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 6, 3 resimden 2. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 6, 3 resimden 3.
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 7, 1 resimden 1.
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: adım 8, 3 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: adım 8, 3 resimden 2. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: adım 8, 3 resimden 3.
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 9, 2 resimden 1. Lenovo Flex 6-11IGM Heat Sink Replacement: adım 9, 2 resimden 2.
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Sonuç
Rie Kuraoka
886 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G10
2 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 281
