Ana içeriğe geç
Giriş
This replacement is extremely easy and doesn't require any tools. Please make sure the computer is off and unplugged before starting the guide.
  1. At the top of the laptop you will see two switches, like in image one and two. Pull the switches outwards with your thumb, towards the unlocked lock. Pull the switches outwards with your thumb, towards the unlocked lock.
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out. Once both switches are pulled, the battery should pop out.
    • Once both switches are pulled, the battery should pop out.
  4. Now you are ready to insert your new battery.
    • Now you are ready to insert your new battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kalah
97 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 23
Her zaman: 339
