Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Once both switches are pulled, the battery should pop out.
Use a JIS #1 screwdriver to remove the two 7 mm screws.
Remove the back panel by sliding it away from the battery.
Use a JIS #1 screwdriver to remove the three 7 mm screws.
Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
The keyboard should only be connected by a ribbon on the underside of the keyboard.
Bu adımda kullanılan alet:Tweezers$4.99-
Use the tweezers to lift the black hinge on the ribbon connector.
Then pull the ribbon from the connector and remove the keyboard from the laptop.
2 farklı kişi bu kılavuzu tamamladı.
