Ana içeriğe geç
Lenovo G40-30 LCD Screen Replacement
Neye ihtiyacın var
  1. Lenovo G40-30 LCD Screen Replacement, Battery: adım 1, 3 resimden 1. Lenovo G40-30 LCD Screen Replacement, Battery: adım 1, 3 resimden 2. Lenovo G40-30 LCD Screen Replacement, Battery: adım 1, 3 resimden 3.
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: adım 2, 3 resimden 1. Lenovo G40-30 LCD Screen Replacement: adım 2, 3 resimden 2. Lenovo G40-30 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 1. Lenovo G40-30 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: adım 5, 2 resimden 1. Lenovo G40-30 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: adım 6, 3 resimden 1. Lenovo G40-30 LCD Screen Replacement: adım 6, 3 resimden 2. Lenovo G40-30 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: adım 7, 2 resimden 1. Lenovo G40-30 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Now you have removed the screen and are ready to install a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jimmy McClenan
156 İtibar
1 Kılavuz yazıldı
Ekip
2 Yorum
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Yanıt
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,449
