Ana içeriğe geç
Lenovo G40-30 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo G40-30 Speaker Replacement, Battery: adım 1, 3 resimden 1. Lenovo G40-30 Speaker Replacement, Battery: adım 1, 3 resimden 2. Lenovo G40-30 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Speaker Replacement: adım 2, 3 resimden 1. Lenovo G40-30 Speaker Replacement: adım 2, 3 resimden 2. Lenovo G40-30 Speaker Replacement: adım 2, 3 resimden 3.
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Speaker Replacement: adım 3, 1 resimden 1.
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Speaker Replacement, Keyboard: adım 4, 2 resimden 1. Lenovo G40-30 Speaker Replacement, Keyboard: adım 4, 2 resimden 2.
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Speaker Replacement: adım 5, 2 resimden 1. Lenovo G40-30 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Speaker Replacement: adım 6, 1 resimden 1.
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Speaker Replacement: adım 7, 2 resimden 1. Lenovo G40-30 Speaker Replacement: adım 7, 2 resimden 2.
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Speaker Replacement: adım 8, 3 resimden 1. Lenovo G40-30 Speaker Replacement: adım 8, 3 resimden 2. Lenovo G40-30 Speaker Replacement: adım 8, 3 resimden 3.
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Speaker Replacement: adım 9, 1 resimden 1.
    • Now your keyboard is free to be replaced!
  10. Lenovo G40-30 Speaker Replacement, Hard Drive: adım 10, 2 resimden 1. Lenovo G40-30 Speaker Replacement, Hard Drive: adım 10, 2 resimden 2.
    • Unscrew four 4mm JIS #0 screws.
  11. Lenovo G40-30 Speaker Replacement: adım 11, 3 resimden 1. Lenovo G40-30 Speaker Replacement: adım 11, 3 resimden 2. Lenovo G40-30 Speaker Replacement: adım 11, 3 resimden 3.
    • After you have the screws out apply pressure with your thumb and slide the hard drive to the left.
    • When the hard drive is completely left gently pull up on the right corner.
  12. Lenovo G40-30 Speaker Replacement, Speaker: adım 12, 2 resimden 1. Lenovo G40-30 Speaker Replacement, Speaker: adım 12, 2 resimden 2.
    • Remove the nine 7mm screws with a JIS #0 screwdriver.
  13. Lenovo G40-30 Speaker Replacement: adım 13, 1 resimden 1.
    • Using the plastic opening tool split open the laptop on the ends. Starting from one side to the other.
  14. Lenovo G40-30 Speaker Replacement: adım 14, 3 resimden 1. Lenovo G40-30 Speaker Replacement: adım 14, 3 resimden 2. Lenovo G40-30 Speaker Replacement: adım 14, 3 resimden 3.
    • These two are the speakers.
    • This is the connector.
    • Unscrew the two 4mm JIS #0 screws.
  15. Lenovo G40-30 Speaker Replacement: adım 15, 3 resimden 1. Lenovo G40-30 Speaker Replacement: adım 15, 3 resimden 2. Lenovo G40-30 Speaker Replacement: adım 15, 3 resimden 3.
    • In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
    • Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
    • Next, use the tweezers to pull the connector out away from the screen.
  16. Lenovo G40-30 Speaker Replacement: adım 16, 1 resimden 1.
    • Now you are ready to install your new speakers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Randall
139 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,527
