Ana içeriğe geç
Lenovo G50-70 Fan Replacement
Neye ihtiyacın var
  1. Lenovo G50-70 Fan Replacement, Battery: adım 1, 3 resimden 1. Lenovo G50-70 Fan Replacement, Battery: adım 1, 3 resimden 2. Lenovo G50-70 Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
    • Push the right switch (labeled 2) to the right. This will eject battery.
  2. Lenovo G50-70 Fan Replacement: adım 2, 1 resimden 1.
    • Rotate the battery away from the laptop.
  3. Lenovo G50-70 Fan Replacement, Back Access Panel: adım 3, 2 resimden 1. Lenovo G50-70 Fan Replacement, Back Access Panel: adım 3, 2 resimden 2.
    • Remove the three 6mm Phillips #0 screws holding the back access panel on.
  4. Lenovo G50-70 Fan Replacement: adım 4, 2 resimden 1. Lenovo G50-70 Fan Replacement: adım 4, 2 resimden 2.
    • Slide the cover toward you to unlatch it.
    • The edge of the panel will slide away from the laptop so it can be lifted.
  5. Lenovo G50-70 Fan Replacement, Fan: adım 5, 2 resimden 1. Lenovo G50-70 Fan Replacement, Fan: adım 5, 2 resimden 2.
    • Remove the three 6mm Phillips #0 screws on the perimeter of the fan.
  6. Lenovo G50-70 Fan Replacement: adım 6, 2 resimden 1. Lenovo G50-70 Fan Replacement: adım 6, 2 resimden 2.
    • The fan is plugged into the motherboard next to the copper heat sync.
    • Unplug the bundled wire connector by pulling up on the white plug.
    • Do not pull up by the wires.
  7. Lenovo G50-70 Fan Replacement: adım 7, 2 resimden 1. Lenovo G50-70 Fan Replacement: adım 7, 2 resimden 2.
    • Lift fan out of case.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
can it take a .5 amp fan??
Basil Jabir - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,162
