Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
Push the right switch (labeled 2) to the right. This will eject battery.
Remove the three 6mm Phillips #0 screws holding the back access panel on.
Slide the cover toward you to unlatch it.
The edge of the panel will slide away from the laptop so it can be lifted.
Start by removing top RAM stick held in by two spring clips on either side.
Press both spring clips away from RAM stick simultaneously.
Lower RAM stick is removed the same way as the first. Pull two spring clips on either side away from RAM stick to release it.
6 farklı kişi bu kılavuzu tamamladı.
