Ana içeriğe geç
Lenovo G50-70 Screen Replacement
Neye ihtiyacın var
  1. Lenovo G50-70 Screen Replacement, Screen: adım 1, 3 resimden 1. Lenovo G50-70 Screen Replacement, Screen: adım 1, 3 resimden 2. Lenovo G50-70 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Push the switches outwards to release the battery.
    • It is important to remove the battery in order to avoid the laptop from turning on and avoiding any electrical issues.
  2. Lenovo G50-70 Screen Replacement: adım 2, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 2, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 2, 3 resimden 3.
    • Use a flat head screwdriver (or a plastic opening tool) to pop off the screen bezel/ plastic cover.
    • Once one side comes off you can use your hands to pull the rest of the plastic cover off; it shouldn't take much force to remove it from the device.
  3. Lenovo G50-70 Screen Replacement: adım 3, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 3, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 3, 3 resimden 3.
    • After removing the plastic cover, gently tilt and lift the screen, but do not remove it from the device.
  4. Lenovo G50-70 Screen Replacement: adım 4, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 4, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove four 3.5 mm screws at the top right and left side of the screen.
  5. Lenovo G50-70 Screen Replacement: adım 5, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 5, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 5, 3 resimden 3.
    • Using the same Phillips #00 screwdriver, remove the four 3.5 mm screws at the bottom of the screen.
  6. Lenovo G50-70 Screen Replacement: adım 6, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 6, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 6, 3 resimden 3.
    • Once the screen is loose and can be moved around, make sure to readjust the laptop gently.
    • Lay the screen flat on the keyboard in order to make it easier to find the connector.
  7. Lenovo G50-70 Screen Replacement: adım 7, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 7, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, peel the sticker to off of the device.
  8. Lenovo G50-70 Screen Replacement: adım 8, 3 resimden 1. Lenovo G50-70 Screen Replacement: adım 8, 3 resimden 2. Lenovo G50-70 Screen Replacement: adım 8, 3 resimden 3.
    • Carefully disconnect the display cable from the rest of the screen.
  9. Lenovo G50-70 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the screen from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Navas
217 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 1,486
