Ana içeriğe geç
Lenovo G50-70 Wireless Card Replacement
Neye ihtiyacın var
  1. Lenovo G50-70 Wireless Card Replacement, Battery: adım 1, 3 resimden 1. Lenovo G50-70 Wireless Card Replacement, Battery: adım 1, 3 resimden 2. Lenovo G50-70 Wireless Card Replacement, Battery: adım 1, 3 resimden 3.
    • Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
    • Push the right switch (labeled 2) to the right. This will eject battery.
  2. Lenovo G50-70 Wireless Card Replacement: adım 2, 1 resimden 1.
    • Rotate the battery away from the laptop.
  3. Lenovo G50-70 Wireless Card Replacement, Back Access Panel: adım 3, 2 resimden 1. Lenovo G50-70 Wireless Card Replacement, Back Access Panel: adım 3, 2 resimden 2.
    • Remove the three 6mm Phillips #0 screws holding the back access panel on.
  4. Lenovo G50-70 Wireless Card Replacement: adım 4, 2 resimden 1. Lenovo G50-70 Wireless Card Replacement: adım 4, 2 resimden 2.
    • Slide the cover toward you to unlatch it.
    • The edge of the panel will slide away from the laptop so it can be lifted.
  5. Lenovo G50-70 Wireless Card Replacement, Wireless Card: adım 5, 3 resimden 1. Lenovo G50-70 Wireless Card Replacement, Wireless Card: adım 5, 3 resimden 2. Lenovo G50-70 Wireless Card Replacement, Wireless Card: adım 5, 3 resimden 3.
    • Disconnect the two plugs on the wireless card by pulling them up with a small tool.
    • Use a plastic spudger to minimize the risk of damage.
  6. Lenovo G50-70 Wireless Card Replacement: adım 6, 2 resimden 1. Lenovo G50-70 Wireless Card Replacement: adım 6, 2 resimden 2.
    • Remove the one 3mm Phillips #0 screw.
  7. Lenovo G50-70 Wireless Card Replacement: adım 7, 1 resimden 1.
    • Lift up wireless card out of plug.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 3,028
