Ana içeriğe geç
Lenovo G50-80 80E5 Fan Replacement
Neye ihtiyacın var
  1. Lenovo G50-80 80E5 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Fan Replacement: adım 2, 3 resimden 1. Lenovo G50-80 80E5 Fan Replacement: adım 2, 3 resimden 2. Lenovo G50-80 80E5 Fan Replacement: adım 2, 3 resimden 3.
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Fan Replacement: adım 3, 3 resimden 1. Lenovo G50-80 80E5 Fan Replacement: adım 3, 3 resimden 2. Lenovo G50-80 80E5 Fan Replacement: adım 3, 3 resimden 3.
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Fan Replacement: adım 4, 3 resimden 1. Lenovo G50-80 80E5 Fan Replacement: adım 4, 3 resimden 2. Lenovo G50-80 80E5 Fan Replacement: adım 4, 3 resimden 3.
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: adım 5, 2 resimden 1. Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: adım 5, 2 resimden 2.
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Fan Replacement: adım 6, 2 resimden 1. Lenovo G50-80 80E5 Fan Replacement: adım 6, 2 resimden 2.
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Rotate the laptop so that you are positioned over the fan.
  8. Lenovo G50-80 80E5 Fan Replacement: adım 8, 1 resimden 1.
    • Remove the three 6 mm screws securing the fan using a Phillips #00 screwdriver.
  9. Lenovo G50-80 80E5 Fan Replacement: adım 9, 1 resimden 1.
    • Unplug the cable from the tri-color end connected to the motherboard.
  10. Lenovo G50-80 80E5 Fan Replacement: adım 10, 1 resimden 1.
    • Remove the fan from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Noah Baldwin
350 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 508
