Ana içeriğe geç
Lenovo G50-80 80E5 RAM Replacement
Neye ihtiyacın var
  1. Lenovo G50-80 80E5 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 RAM Replacement: adım 2, 3 resimden 1. Lenovo G50-80 80E5 RAM Replacement: adım 2, 3 resimden 2. Lenovo G50-80 80E5 RAM Replacement: adım 2, 3 resimden 3.
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 RAM Replacement: adım 3, 3 resimden 1. Lenovo G50-80 80E5 RAM Replacement: adım 3, 3 resimden 2. Lenovo G50-80 80E5 RAM Replacement: adım 3, 3 resimden 3.
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 RAM Replacement: adım 4, 3 resimden 1. Lenovo G50-80 80E5 RAM Replacement: adım 4, 3 resimden 2. Lenovo G50-80 80E5 RAM Replacement: adım 4, 3 resimden 3.
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: adım 5, 2 resimden 1. Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: adım 5, 2 resimden 2.
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 RAM Replacement: adım 6, 2 resimden 1. Lenovo G50-80 80E5 RAM Replacement: adım 6, 2 resimden 2.
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 RAM Replacement, RAM: adım 7, 2 resimden 1. Lenovo G50-80 80E5 RAM Replacement, RAM: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to push the two silver clips to the left and right of the RAM chip outwards.
    • The RAM will release after pushing the second clip.
  8. Lenovo G50-80 80E5 RAM Replacement: adım 8, 1 resimden 1.
    • Use your fingers to carefully remove the RAM chip by sliding it out at a ~45° angle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Noah Baldwin
350 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 1,234
