Ana içeriğe geç
Lenovo G50-80 80E5 Removing top panel Replacement
Neye ihtiyacın var
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: adım 1, 1 resimden 1.
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 2, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 2, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 2, 3 resimden 3.
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: adım 3, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 3, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 3, 3 resimden 3.
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: adım 4, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 4, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 4, 3 resimden 3.
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: adım 5, 2 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: adım 5, 2 resimden 2.
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: adım 6, 2 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 6, 2 resimden 2.
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: adım 7, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: adım 7, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: adım 7, 3 resimden 3.
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: adım 8, 1 resimden 1.
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: adım 9, 2 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 9, 2 resimden 2.
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: adım 10, 1 resimden 1.
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: adım 11, 1 resimden 1.
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: adım 13, 2 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 13, 2 resimden 2.
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: adım 14, 1 resimden 1.
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: adım 15, 1 resimden 1.
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: adım 16, 1 resimden 1.
    Satın Al
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: adım 17, 1 resimden 1.
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: adım 18, 1 resimden 1.
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: adım 19, 1 resimden 1.
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: adım 20, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 20, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 20, 3 resimden 3.
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: adım 21, 1 resimden 1.
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: adım 22, 2 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 22, 2 resimden 2.
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: adım 23, 1 resimden 1.
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: adım 24, 1 resimden 1.
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: adım 25, 3 resimden 1. Lenovo G50-80 80E5 Removing top panel Replacement: adım 25, 3 resimden 2. Lenovo G50-80 80E5 Removing top panel Replacement: adım 25, 3 resimden 3.
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: adım 26, 1 resimden 1.
    • Top covered removed
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Victor
1.282 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 62
Her zaman: 7,438
