Ana içeriğe geç
Lenovo G70-70 Keyboard Replacement
Neye ihtiyacın var
    1. Lenovo G70-70 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Lenovo G70-70 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
      • Ensure the battery is removed before attempting to fix anything on the laptop.
      • Orient the laptop so the bottom side is facing you.
      • To unlock the battery, place your thumb over the left switch and slide it to the left.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-70 Keyboard Replacement: adım 2, 2 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 2, 2 resimden 2.
      • To access the battery, place your thumb over the right switch and slide it to the right.
      • When the battery is unlocked, it will automatically pop up.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo G70-70 Keyboard Replacement: adım 3, 3 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 3, 3 resimden 2. Lenovo G70-70 Keyboard Replacement: adım 3, 3 resimden 3.
      • Remove the battery by lifting it up and away from yourself.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo G70-70 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Lenovo G70-70 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Lenovo G70-70 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
      • Turn your laptop so the bottom side is facing you.
      • Remove two 7.3 mm Phillips #0 screws.
      • Slide the back cover towards yourself.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-70 Keyboard Replacement: adım 5, 3 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 5, 3 resimden 2. Lenovo G70-70 Keyboard Replacement: adım 5, 3 resimden 3.
      • Lift the back cover from the far side towards yourself to remove it.
      • Remove three 6.2 mm Phillips #0 screws.
      • The label M2X6 is written next to each screw that keeps the keyboard secure.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo G70-70 Keyboard Replacement: adım 6, 3 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 6, 3 resimden 2. Lenovo G70-70 Keyboard Replacement: adım 6, 3 resimden 3.
      • Turn the laptop over so the top side is facing you and open the laptop.
      • Carefully pry open any corner of the keyboard with the metal spudger.
      • Slide the metal spudger around the perimeter of the keyboard until you can lift it.
      • You will hear loud popping noises as the keyboard separates from the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo G70-70 Keyboard Replacement: adım 7, 2 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 7, 2 resimden 2.
      • Carefully lift the keyboard.
      • Use your finger or the opening tool to pull the locking flap toward yourself.
      FixBot'a Sor
      Yorum Ekle
    5. Lenovo G70-70 Keyboard Replacement: adım 8, 2 resimden 1. Lenovo G70-70 Keyboard Replacement: adım 8, 2 resimden 2.
      • Pull the silver ribbon cable away from you to disconnect the keyboard.
      • Remove the keyboard from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Crews
842 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 560
