Ana içeriğe geç
Lenovo G70-80 RAM Replacement
Neye ihtiyacın var
    1. Lenovo G70-80 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the computer.
      • Set the computer upside down with the back facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-80 RAM Replacement: adım 2, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 2, 2 resimden 2.
      • Located directly below the bottom plate will be two switches near where the battery is located.
      • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
      • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo G70-80 RAM Replacement: adım 3, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 3, 2 resimden 2.
      • Slide the left battery release switch to the left.
      • While holding the switch to the left, lift the battery to remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo G70-80 RAM Replacement: adım 4, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 4, 2 resimden 2.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 1. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 2. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 3.
      • Remove the placeholder screws and pull off the backplate.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 1. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 2. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 3.
      • Carefully pull the two metal retaining clips away from the sides of the RAM module.
      • As the clips release, the RAM module should pop up at an angle.
      • Remove the RAM from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 1,551
