Ana içeriğe geç
Lenovo G70-80 RAM Replacement
Neye ihtiyacın var
  1. Lenovo G70-80 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 RAM Replacement: adım 2, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 2, 2 resimden 2.
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 RAM Replacement: adım 3, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 3, 2 resimden 2.
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 RAM Replacement: adım 4, 2 resimden 1. Lenovo G70-80 RAM Replacement: adım 4, 2 resimden 2.
    • Remove the battery.
  5. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 1. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 2. Lenovo G70-80 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Remove the placeholder screws and pull off the backplate.
  6. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 1. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 2. Lenovo G70-80 RAM Replacement: adım 6, 3 resimden 3.
    • Carefully pull the two metal retaining clips away from the sides of the RAM module.
    • As the clips release, the RAM module should pop up at an angle.
    • Remove the RAM from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 926
