Ana içeriğe geç
Lenovo G70-80 Screen Replacement
Neye ihtiyacın var
    1. Lenovo G70-80 Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the computer.
      • Set the computer upside down with the back facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-80 Screen Replacement: adım 2, 2 resimden 1. Lenovo G70-80 Screen Replacement: adım 2, 2 resimden 2.
      • Located directly below the bottom plate will be two switches near where the battery is located.
      • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
      • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo G70-80 Screen Replacement: adım 3, 2 resimden 1. Lenovo G70-80 Screen Replacement: adım 3, 2 resimden 2.
      • Slide the left battery release switch to the left.
      • While holding the switch to the left, lift the battery to remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo G70-80 Screen Replacement: adım 4, 2 resimden 1. Lenovo G70-80 Screen Replacement: adım 4, 2 resimden 2.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Lenovo G70-80 Screen Replacement, Screen: adım 5, 1 resimden 1.
      • Open the laptop to face the screen.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo G70-80 Screen Replacement: adım 6, 3 resimden 1. Lenovo G70-80 Screen Replacement: adım 6, 3 resimden 2. Lenovo G70-80 Screen Replacement: adım 6, 3 resimden 3.
      • Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
      • The bezel is the plastic frame around the laptop screen.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo G70-80 Screen Replacement: adım 7, 2 resimden 1. Lenovo G70-80 Screen Replacement: adım 7, 2 resimden 2.
      • After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
      • If you are having trouble removing the bezel from the LCD panel, pull both sides of the bezel towards you with your hands.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo G70-80 Screen Replacement: adım 8, 3 resimden 1. Lenovo G70-80 Screen Replacement: adım 8, 3 resimden 2. Lenovo G70-80 Screen Replacement: adım 8, 3 resimden 3.
      • Use a screwdriver to remove the screws that secure the LCD panel to the computer.
      • Once the bezel is removed, you will see eight screws around the screen that secure the LCD panel to the computer.
      FixBot'a Sor
      Yorum Ekle
    5. Lenovo G70-80 Screen Replacement: adım 9, 1 resimden 1.
      • Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
      FixBot'a Sor
      Yorum Ekle
    6. Lenovo G70-80 Screen Replacement: adım 10, 1 resimden 1.
      • Disconnect the LCD panel from the computer by peeling the connector off.
      FixBot'a Sor
      Yorum Ekle
    7. Lenovo G70-80 Screen Replacement: adım 11, 2 resimden 1. Lenovo G70-80 Screen Replacement: adım 11, 2 resimden 2.
      • With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
      • There is one screw on each corner that connects to the mounting arms.
      FixBot'a Sor
      Yorum Ekle
    8. Lenovo G70-80 Screen Replacement: adım 12, 1 resimden 1.
      • Remove the LCD panel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
how do you repair a whitescreen effect for a lenovo110 ideapad
sidney ifedha - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 2,083
